Fix Public Link Not Supported Errors — Share Files Correctly with RcloneView
Right-click Get Public Link and nothing happens — here's why, and what to do instead.
RcloneView's Explorer panel offers a Get Public Link command in the right-click menu, but it only works on remotes whose backend exposes a native sharing API. Try it on a plain protocol connection or an unsupported provider and the request fails or returns an error instead of a URL. RcloneView's Remote Manager and dual-pane Explorer make it easy to see which remote you're on and move the file somewhere link-friendly instead.
Public link generation depends on what the underlying storage backend supports. Providers with a native sharing API — Google Drive, Dropbox, Microsoft OneDrive, Box, and pCloud among them — return a shareable URL because rclone calls that provider's own link endpoint. Protocol-based connections like SFTP, FTP, WebDAV, and SMB/CIFS have no such concept; they're direct file transport protocols, not sharing platforms, so there's nothing for the command to call. S3-compatible endpoints (Amazon S3, Wasabi, Backblaze B2, Cloudflare R2) handle public access through bucket policies or pre-signed URLs set up on the provider's own console instead.
RcloneView new remote screen showing different provider types
Before assuming a bug, check which category your remote falls into. Open Remote Manager from the Remote tab and confirm the remote type — a quick glance often explains the failure immediately.
Confirm the Remote and Permission Settings​
If the remote is one of the OAuth-based providers that should support linking, the next step is verifying the account has permission to share the specific file or folder. Business and enterprise variants of these remotes sometimes restrict external sharing at the organization level, which surfaces in RcloneView as the same failed request. Re-authenticate the remote through Remote Manager if the token looks stale, and retry on a file you know is shareable from the provider's own web interface first.
RcloneView folder compare view for verifying file locations before sharing
Unlike mount-only tools, RcloneView also syncs and compares folders — on the FREE license — so you can quickly copy a file from a non-linkable remote into a sharing-capable one instead of troubleshooting further.
For SFTP, FTP, WebDAV, SMB, and most S3-compatible buckets, the practical fix is to copy the file to a remote that does support native links, or hand off distribution through the provider's own console (bucket policy, pre-signed URL, or NAS-side share). Use RcloneView's drag-and-drop between two open Explorer panels to move a copy across, then run Get Public Link on the destination remote.
RcloneView job scheduling for repeatable copy-and-share workflows
If this is a recurring need, save the copy step as a Job in Job Manager so the same files land in your linkable remote automatically after every sync.
  2. Open Remote Manager to confirm which backend type the failing remote actually uses.
  3. Re-authenticate OAuth remotes whose tokens may have expired, then retry the link on a known-shareable file.
  4. For protocol or S3-compatible remotes, copy the file into a linkable remote using drag-and-drop, then generate the link there.
Knowing which remotes can share links before you need one saves a support ticket later.
