Fix Box Upload Errors — How to Resolve Transfer Issues with RcloneView
· 5 min read
A single Box API error can silently stall a sync job — here's how to diagnose the exact cause and fix it in RcloneView.
Box is a widely used enterprise cloud platform, but its API enforces rate limits, token expiry windows, and file path rules that can cause uploads to fail mid-transfer. When a sync job stops without a clear message, most users restart the entire job and hope for better luck. RcloneView gives you structured log output, configurable retry behavior, and per-remote authentication controls — the right tools to pinpoint the real problem and prevent it from recurring.
Common Causes of Box Upload Errors​
Box upload failures generally fall into a few categories. API rate limiting is the most frequent culprit: when RcloneView sends too many concurrent requests, Box returns HTTP 429 errors and throttles the connection. Running more than the default number of parallel transfers to Box can trigger this, especially against a Box for Business account with stricter API quotas.
Expired OAuth tokens are the second leading cause. Box access tokens expire after a fixed period. If a long-running job is in progress when the token expires, uploads begin failing with authentication errors. RcloneView stores your Box credentials securely and refreshes access tokens when they expire, but if the refresh token itself has expired — typically after extended inactivity — you need to re-authenticate the remote.
File path and naming issues also cause errors. Box enforces restrictions on certain special characters and file path lengths. Files with characters that Box doesn't accept will fail silently unless logging is enabled.
RcloneView showing a Box sync transfer job in progress
Read the Logs to Identify the Exact Error​
Before changing any settings, enable debug logging to capture the full error context. In RcloneView, go to Settings > Embedded Rclone and check Enable rclone Logging, then set the log level to DEBUG. Click Restart Embedded Rclone, then reproduce the upload failure. Open the log file from the configured log folder — the error code and HTTP response from Box will be clearly recorded.
Alternatively, check the Log tab at the bottom of the RcloneView interface for timestamped error entries from the current session. The Job History tab (accessible via Job Manager) records status, duration, and transfer speed for every past job. A job that completed with an "Errored" status contains the file count and size context you need to scope the problem.
Job history in RcloneView showing Box sync error details
Adjust Transfer Settings to Match Box's Limits​
Once you know the error type, open the affected job in Job Manager and click Edit. In Step 2 (Advanced Settings), reduce the Number of file transfers to lower the concurrent request count — starting with 2 or 3 is a safe baseline for Box. Also reduce Number of equality checkers to 4 or fewer, as Box can struggle with high parallelism on the metadata side too.
Increase the Retry entire sync if fails count from the default of 3 to 5 or higher for flaky network conditions. RcloneView's retry logic skips already-transferred files on subsequent passes, so retrying doesn't duplicate work — it picks up exactly where the previous attempt left off. Enable checksum verification if data integrity is critical, though this increases request volume, so combine it with lower concurrency settings.
Configuring advanced transfer settings for Box in RcloneView
Re-authenticate Box When Token Errors Persist​
If logs show persistent authentication failures even after reducing concurrency, the Box OAuth token needs refreshing. In RcloneView, go to Remote tab > Remote Manager, select your Box remote, and click Edit. Re-running the OAuth flow opens a browser window for you to sign in to Box again, issuing a fresh token pair. For Box for Business accounts, confirm that the box_sub_type = enterprise setting is still present in the remote configuration before saving.
After re-authentication, run the job again. Use the Dry Run option (available in Job Manager) to preview which files will be transferred without making actual changes — this lets you confirm the connection works and the file list is as expected before committing a full upload.
  2. Enable DEBUG logging in Settings > Embedded Rclone and reproduce the upload error to capture the exact error code.
  3. Edit the failing job in Job Manager, reduce concurrent transfers to 2–3, and increase the retry count.
  4. If authentication errors persist, re-authenticate the Box remote via Remote Manager and use Dry Run to confirm connectivity before running the full job.
With the right concurrency settings and a valid token, Box uploads through RcloneView run reliably — even for large enterprise archives spanning tens of thousands of files.
