Fix IONOS Object Storage Connection Errors — Endpoint and Key Problems Resolved with RcloneView
· 3 min read
Casey
Product Manager
Most IONOS Object Storage connection failures come down to the endpoint, the region, or the key pair — and RcloneView gives you a GUI-based way to check each one.
IONOS Object Storage is accessed through rclone's S3 protocol, which means a single mistyped endpoint or a swapped key can produce errors that look unrelated. RcloneView lets you inspect the remote, read the logs, and test commands in the built-in terminal without leaving the app.
Check the Endpoint and Region First​
S3-compatible providers require an Access Key, Secret Key, and an endpoint. If the endpoint does not match the region where the bucket was created, requests fail even though the keys are correct. Typical symptoms are timeouts, "no such host" messages, or a bucket that cannot be found.
Open Remote Manager from the Remote tab, edit the IONOS remote, and compare the endpoint against the one shown in your IONOS control panel for that bucket's region.
Editing an IONOS Object Storage remote endpoint in RcloneView
Re-enter and Test the Key Pair​
Access denied or signature errors usually mean the Access Key or Secret Key was pasted with extra whitespace, or the key was regenerated. Re-enter both values, save, and browse the remote root in an Explorer panel.
If you prefer the command line, open the Terminal tab and run rclone listremotes, then rclone about "yourremote:" to confirm the remote responds. The terminal uses the same configuration as the GUI, so the result tells you exactly what the app sees.
Browsing the IONOS remote in an RcloneView Explorer panel
Capture Logs for Stubborn Errors​
When the cause is still unclear, open Settings > Embedded Rclone, enable rclone Logging, set the level to DEBUG, and restart the embedded rclone. Reproduce the failure and read the log: it shows the exact request and the response code. Also check Global Rclone Flags in the same settings page, since a leftover flag can change connection behavior.
Job History showing a failed IONOS Object Storage sync job
Confirm Recovery With a Dry Run​
Once the remote lists correctly, rerun your sync job with a Dry Run to preview copies and deletions. Reduce concurrent transfers in Step 2 if errors appear only under heavy load, and keep retries at the default of 3.
Running a verified IONOS Object Storage job in RcloneView
  2. Verify the IONOS endpoint matches your bucket's region in Remote Manager.
  3. Re-enter the Access Key and Secret Key, then test with rclone about in the Terminal tab.
  4. Enable DEBUG logging if needed, then confirm with a Dry Run.
Checking endpoint, keys, and logs in order turns a confusing connection error into a short checklist.
