Fix Linode Object Storage Connection Errors — Resolve with RcloneView
· 3 min read
Connection failures to Linode Object Storage are almost always a mismatched endpoint or region, not a broken account — here's how to diagnose and fix them in RcloneView.
Linode Object Storage is accessed through rclone's S3-compatible protocol, which means the remote needs an exact Access Key, Secret Key, and regional endpoint to authenticate correctly. A single typo in the endpoint URL, or a bucket created in a different cluster than the one configured, produces connection errors that look like generic network failures rather than what they actually are: a mismatch. RcloneView surfaces these errors in the Log tab, making it far easier to pinpoint the cause than reading raw rclone CLI output.
Common Causes of Linode Object Storage Connection Errors​
The most frequent cause is an endpoint that doesn't match the bucket's cluster region — for example, configuring us-east-1.linodeobjects.com while the bucket actually lives in eu-central-1. Since Linode Object Storage buckets are region-locked, RcloneView will report authentication or "bucket not found" errors even when the Access Key and Secret Key are valid. Double-check the exact region shown in the Linode Cloud Manager against the endpoint entered in the remote's connection settings.
Expired or regenerated Access Keys are the second common trigger. If a key was rotated in the Linode dashboard but not updated in RcloneView, requests will fail with an authentication error rather than a clear "key expired" message.
Creating a new S3-compatible remote for Linode Object Storage in RcloneView
Rebuilding the Remote Connection​
Open Remote Manager, select the affected Linode remote, and verify each field individually: Access Key ID, Secret Access Key, and Endpoint. Re-enter the endpoint exactly as shown in the Linode dashboard, including the cluster prefix. RcloneView mounts AND syncs 90+ providers from one window, on Windows, macOS, and Linux, so once the endpoint is corrected, both file browsing and any scheduled sync jobs pointing to that remote resume without needing to rebuild your job configuration.
After updating credentials, use the Rclone Terminal tab and run rclone about "remote:" to confirm the connection reports available storage before trusting it for a live sync.
Verifying Linode Object Storage connection status in RcloneView
Preventing Repeat Failures​
Run a Dry Run before any scheduled sync against the corrected remote — it lists exactly which files would transfer without moving data, catching lingering endpoint issues before they affect production backups. If errors persist, enable rclone Logging at DEBUG level in Settings to capture the full request/response cycle for deeper diagnosis.
Reviewing job history after fixing a Linode Object Storage connection
  2. Open Remote Manager and locate your Linode Object Storage remote.
  3. Verify the Access Key, Secret Key, and regional Endpoint match the Linode dashboard exactly.
  4. Run a Dry Run before resuming any scheduled sync jobs against the remote.
A correctly configured endpoint means Linode Object Storage behaves as reliably as any other S3-compatible remote in your workflow.
