Mount Box Storage as a Network Drive with RcloneView for Seamless Team Access
· 2 min read
Stop downloading everything from Box. Mount it as a drive, browse in Explorer or Finder.
Box is excellent for collaboration, but local sync clients can bloat disks and slow laptops. With RcloneView you can mount Box as a network drive, stream files on demand, and control cache and bandwidth so teams get fast access without full downloads.
Why Mount Box Instead of Syncing?​
  • Save disk space on shared devices; fetch only what users open.
  • Faster onboarding: map one drive letter or mount path and skip initial bulk syncs.
Step 1 — Connect Box in RcloneView​
  • Add Box via + New Remote (OAuth flow). Guide: add-oath-online-login.
  • Verify the remote in Remote Explorer so you know folders and depth look right.
Step 2 — Mount Box as a Drive (Windows or macOS)​
  • Open Mount Manager and select your Box remote. Guide: mount-cloud-storage-as-a-local-drive.
  • Choose a target:
    • Windows: assign a drive letter (e.g., B:) using cmount under the hood.
    • macOS: pick a mount path (e.g., /Volumes/Box).
  • Save and mount; confirm the drive appears in Explorer or Finder.
Step 3 — (Optional) Use Compare Before Big Moves​
  • Run Compare to see differences between Box and a local or secondary cloud before making structural changes: compare-folder-contents.
  • Catch missing or newer files without risking an accidental overwrite.
Compare shared folder and My Drive contents
Step 5 — (Optional) Sync Jobs and Backups​
  • Mirror critical Box folders to a backup target (S3, Wasabi, NAS) with copy or sync jobs: create-sync-jobs.
  • Start with copy for safety; switch to sync after validating results.
  • Schedule off-hours runs so workday mounts stay snappy.
Mount Box once, tune cache, and give teams a fast, low-overhead network drive without heavyweight sync clients. RcloneView keeps everything visible, logged, and easy to manage.
