Remote Management Guide — Add, Edit, and Organize Cloud Connections in RcloneView
· 3 min read
Your first remote takes 2 minutes to set up. Your 15th needs a system. Here's how to manage all your cloud connections efficiently as your multi-cloud setup grows.
Every cloud provider in RcloneView starts as a "remote" — a named connection with credentials and configuration. When you have two or three remotes, management is simple. But as you add more providers (and many users end up with 10+), keeping them organized becomes essential. This guide covers everything from adding your first remote to managing a complex multi-cloud setup.
Adding a New Remote​
Add new remote
The remote manager walks you through adding any of 70+ providers. Each provider type has different configuration fields — Google Drive uses OAuth, S3 uses access keys, WebDAV uses URL and credentials.
Common provider types​
Connection TypeExamplesAuth Method
OAuthGoogle Drive, OneDrive, DropboxBrowser login
Access KeysS3, B2, Wasabi, R2Key + Secret
Username/PasswordWebDAV, FTP, SFTPCredentials
TokenBox, MegaAPI token
Naming Conventions​
Good naming saves confusion later. Consider these patterns:
  • By provider: gdrive-personal, gdrive-work, s3-backup
  • By purpose: backup-primary, backup-secondary, archive
  • By team: marketing-drive, engineering-s3, finance-onedrive
Editing Remote Configuration​
Need to update credentials, change endpoints, or modify settings? Edit any remote through the remote manager without recreating it.
Common reasons to edit:
  • Expired OAuth tokens — re-authorize without losing job configurations
  • Changed access keys — update S3 credentials after rotation
  • Different endpoint — switch S3 regions or custom endpoints
Advanced Configuration​
Crypt remotes​
Create encrypted wrappers around existing remotes. A crypt remote encrypts file names and contents before they reach the cloud:
Union/Combine remotes​
Merge multiple remotes into a single virtual view. Useful for combining free storage tiers across providers.
Organizing Your Remotes​
As your remote count grows:
  • Use consistent naming so remotes sort logically
  • Document your setup — which remote backs up to which
  • Clean up unused remotes — remove old trial accounts
  • Test connections periodically — expired tokens cause silent failures
Using Remotes in the Explorer​
Once configured, remotes appear in the two-pane explorer. Select any remote as the source or destination pane:
Browse remotes in explorer
  2. Add your first remote — follow the guided setup.
  3. Name it clearly for future reference.
  4. Add more remotes as needed.
  5. Keep them organized with consistent naming.
Good remote management is the foundation of good cloud management.
