Manage Rclone Connections in RcloneView
RcloneView is a GUI-based file manager for cloud storage that communicates with Rclone via its Remote Control (RC) API. By default, it comes bundled with an Embedded Rclone instance but also supports connecting to external Rclone instances (External Rclone).
This guide explains how to manage these connections using the Connection Manager.
Connection Manager Overview​
RcloneView communicates with Rclone in two modes:
  • Embedded Rclone (default, built-in)
  • External Rclone (user-configured, network-connected)
The Connection Manager allows you to view, switch, and manage these Rclone instances.
connection manager with embedded rclone only
Embedded Rclone​
RcloneView includes a pre-installed Rclone binary called Embedded Rclone, which launches automatically.
FieldDescription
AddressTypically http://127.0.0.1:5582 (localhost loopback)
Rclone VersionExample: v1.70.1
Connected / ConnectIndicates the current status. If not connected, click Connect to activate.
Self UpdateClick to upgrade to the latest Rclone version.
External Rclone List​
External Rclone refers to a standalone Rclone instance launched manually by the user, typically via rclone rcd. It could be running on:
  • A local machine (for testing)
  • A remote server (e.g., AWS EC2)
  • Inside a Docker container
Each entry displays:
FieldDescription
Display NameUser-defined name (e.g., aws-rclone)
Remote AddressAPI endpoint, e.g., http://<host>:5572
UsernameIf authentication is enabled
Rclone VersionRetrieved from the connected instance
Available Actions:
  • Connect – Makes this instance active
  • Edit – Modify address, credentials, or SSL options
  • Delete – Remove from the list
external rclone addedexternal rclone selected
Current Selection Indicator​
At the top of the Connection Manager dialog:
  • Selected: Embedded Rclone – the default built-in instance is active
  • Selected: aws-rclone – a custom external instance is in use
Only one connection can be active at a time. Your current selection affects:
  • Remote list visibility
  • Mount/Job actions
  • Configuration operations
Notes
  • Only one Rclone connection can be active at any time.
  • You can switch freely between Embedded and External connections.
💡 To manage two instances side-by-side, open a new RcloneView window.
  • If an external Rclone becomes unavailable, you can always fall back to the embedded version.
Add a New External Rclone​
To connect to a running rclone rcd server:
new connection form
  1. Click New Connection at the bottom of the Connection Manager.
  2. Fill in the form:
FieldDescription
Display Namee.g., aws-rclone
Remote AddressFull API endpoint (http://<host>:5572)
Username / PasswordRequired if authentication is enabled
Disable SSL VerificationFor self-signed certificates or dev use
  1. Click Test connection. If successful, click Save.
Notes
💡 To make an external Rclone available, run it with:
rclone rcd --rc-user=<user> --rc-pass=<pass> --rc-addr=127.0.0.1:5572
