File Management with RcloneView
RcloneView allows you to easily browse, transfer, and organize files between your local disk and multiple cloud storage services using a familiar, Explorer-like interface.
This guide walks you through:
  • Browsing remote storage
  • Copying files using drag & drop
  • Managing files with the right-click menu
Browsing Remote Storage​
You can open any connected cloud remote and view it like a local folder.
How to Browse a Remote:​
  1. Click the + tab in the Explorer pane.
  2. Select the remote storage you want to open.
  3. The selected remote will open in a new tab, ready for file operations.
file explorer open remotefile explorer remote open complete
View Layout
Go to Settings > Layout to switch between vertical and horizontal views
explorer view layout
Copying Files using Drag and Drop​
You can transfer files between local and cloud storage using simple drag & drop.
Copy Between Two Remotes​
Drag files from one remote tab to another in RcloneView to copy them across cloud storages.
👉 For Multi-Select and Bulk Actions You can select multiple files at once to perform batch operations.
  • Use Ctrl + Click to select multiple individual files.
  • Use Shift + Click to select a range of files.
**👉 Drag & Drop Behavior **
  • Same remote = Move operation
  • Different remotes = Copy operation
Hint
  • If you don’t want to see the confirmation popup during copy, uncheck the Confirm drag and drop checkbox.
  • To re-enable the popup later, go to Settings > General settings > Confirm drag and drop and check it again.
Copy from Windows Explorer to Remote in RcloneView​
  • You can also drag files directly from Windows File Explorer into a RcloneView tab to upload them to the cloud storage.
Managing files with the right-click menu​
RcloneView supports full file operations through a convenient right-click menu.
Available Actions:​
  • download iconDownload – Save file(s) to your local disk
  • upload iconUpload – Send local file(s) to a cloud remote
  • copy iconCopy / paste iconPaste – Copy files between folders or remotes
  • cut iconCut / paste iconPaste – Move files to another location
  • delete iconDelete – Remove files or folders
  • rename iconRename – Rename files or folders
  • new folder iconNew Folder – Create a new folder
  • refresh iconReload – Refresh folder contents
