Synchronize Remote Storages Instantly
Use RcloneView's Sync feature to instantly mirror folders between cloud remotes or local storage.
This guide walks you through setting up and running a sync operation.
Select source and destination folders​
To begin a sync operation, you need to define the Source and Destination folders.
  • In the Explorer panel, open two tabs:
    • The folder selected on the left tab becomes the Source
    • The folder selected on the right tab becomes the Destination
  • You can also enter folder paths directly using the Path Bar at the top of each tab.
  • These settings can later be adjusted in the Sync configuration window if needed.
Once the folders are selected, click the Sync button in the top Home menu to proceed.
sync remote folder select
Run sync operation​
After selecting the source and destination folders, you can configure and run your sync.
sync configure storagesync advanced settingssync filtering settings
Step 1: Verify folder paths​
  • In the Configure Storage step, review the selected source and destination folders.
  • Make sure both are correctly set before clicking Next.
How sync works
RcloneView Sync make source and dest identical.
This means modifying destination only.
  • The contents of the source folder are mirrored to the destination.
  • Any existing files in the destination that do not exist in the source will be deleted.
👍 Important: Rclone officially supports one-directional sync only.
⚠️ Bidirectional sync (=Bidirection) is available as a beta feature and is not officially supported.  It may cause unexpected behavior or errors, so it is not recommended for production use.
Configure Storage Details
sync config storage details
  1. Select the source folder.
  • Click the folder icon in the left panel to choose the source.
  1. Select the destination folder.
  • Click the folder icon in the right panel to choose the destination.
  1. Add additional destinations (optional).
  • Click the Add Destination button to sync to multiple destinations at once. You can configure 1:N sync if needed.
  1. Choose the sync direction.
  • Modifying destination only: Syncs from source to destination. Updates or deletes destination content to match the source.
  • Bidirection (Beta): Compares both folders and syncs changes in both directions.
    ⚠️ This mode may overwrite new files unintentionally, so use with caution.
  1. Create empty directories (optional).
  • If enabled, any source directories that contain no files will be recreated as empty folders in the destination.
Using Bidirectional Sync in RcloneView
RcloneView uses bisync (a beta command in rclone) to perform bidirectional sync.   Since this feature is still experimental, we recommend reviewing the official user manual — especially the Limitations section — before enabling it.
Using bisync incorrectly may result in data loss. Please use with caution.
Step 2: Advanced Settings (optional)​
  • Advanced Settings include options for:
    • Transfer performance
    • Connection method
    • Error handling behavior
💡 We recommend using the default values unless you need custom behavior.
Advanced Settings Details
sync advanced settings details
Performance :
  1. Number of file transfers:
    The number of file transfers to run in parallel. It can sometimes be useful to set this to a smaller number if the remote is giving a lot of timeouts or bigger if you have lots of bandwidth and a fast remote.
  2. Number of multi thread transfers:
    When using multi thread transfers this sets the number of streams to use. Set to 0 to disable multi thread transfers (Default 4). When transferring files above 256MB to capable backends, rclone will use multiple threads to transfer the file.
  3. Number of equaility checkers:
    checkers do the equality checking of files during a sync. For some storage systems (e.g. S3, Swift, Dropbox) this can take a significant amount of time so they are run in parallel. The default is to run 8 checkers in parallel. However, in case of slow-reacting backends you may need to lower (rather than increase) this default by setting --checkers to 4 or less threads.
Safety and Integrity :
  1. Enable checksum to compare files :
    Normally rclone will look at modification time and size of files to see if they are equal. If you set this flag then rclone will check the file hash and size to determine if files are equal.This is very useful when transferring between remotes which store the same hash type on the object, e.g. Drive and Swift. For details of which remotes support which hash type see the table in the overview section.
Error control :
  1. Retry the entire sync if it fails this many times:
    Retry the entire sync if it fails this many times it fails (default 3). Some remotes can be unreliable and a few retries help pick up the files which didn't get transferred because of errors. Disable retries with 1.
Step 3: Filter files and folders (optional)​
  • RcloneView applies basic filters by default for services like Google Docs or Box Docs.
  • You can add more file types or folders to exclude from the sync.
Filering Settings Details
sync filtering settings details
  1. Don't sync files over :
    Controls the maximum file size allowed for sync.   Default unit is MB.
  2. Don't sync files older than this :
    Controls the maximum file age allowed for sync.   This applies to files only, not directories.   Use the following units:
    y = years, d = days, h = hours, m = minutes, s = seconds  (Example: 2y30d12h30m45s)
  3. Don't sync folders over this depth :
    If set, Rclone will only sync folders within the specified depth.   For example, setting this to 1 will only sync files in the top-level directory.   Setting it to 2 will sync files within the first two folder levels, and so on.
  4. Predefined Filters.
    You can quickly apply built-in filters for common file types such as:
       - Music, Video, Image, Document, Google Docs, Box Docs      These filters are available as predefined options in the filter list.
  5. Others (= Custom Filters).
    You can define custom rules to exclude or include specific file types, folders, or paths.   Here are some common examples:
    .iso : Exclude all .iso files.
    /.git/* : Exclude only files inside the .git folder in the root, not subfolders.
    /.git/ : Exclude the entire .git folder in the root, including everything inside it.
    .git/ : Exclude all .git folders and everything inside them, regardless of location.
    🔗 For more advanced examples and syntax, refer to the Rclone Filtering Guide
Step 4: Run sync​
  • Once all settings are complete, click Run to start the sync process.
Sync Scheduling.
To run sync tasks on a scheduled date and time, first Save to Jobs to register the sync task as a job. Then, run the Job Manager to configure the schedule.
⚠️ Job scheduling is available as a PLUS feature.
You will need to purchase a PLUS license to enable this functionality.
Simulate: Run a dry run (optional)​
You can run a Dry run to simulate the sync operation without making any actual changes.
  • This preview shows which files will be copied to the Destination and which files will be deleted.
  • Click See details to view a full list of operations that would occur (e.g., copy, create, delete) in the destination.
sync dry runsync dry run details
Monitor sync results​
You can check the progress and results of sync operations in real time.
Transfer status (in progress)​
  • During sync, open the Transfer tab to view real-time progress of each file.
  • Click the + icon to expand and monitor individual file transfers.
sync transfer window
Completed jobs (after sync)​
  • Once the sync is finished, go to the Completed tab to view the results.
  • Click the + icon to see file-level details of each completed job.
sync completed window
Quickly open synced remotes
In the Completed tab, you can double-click any completed job to open both the source and destination folders in the Explorer panel.   This makes it easy to review the synced folders immediately.
Completion notification alarm (Windows)​
After the sync is complete, a notification popup will appear in the Windows system tray, showing a summary of the sync operation.
  • You can click See details to view a full breakdown of the results.
sync completed windows alarm
See the alarm messages on Windows notification
If you miss the popup, you can still check the sync alert by clicking the notification icon in the Windows system tray.
click windows alarm notification
Save sync operation as a Job​
If you regularly perform the same sync task, you can save it as a Job for easy reuse.
  • Click Save to Jobs after configuring your sync.
  • Enter a Job Name, then click Save to store the job.     - ❗Allowed characters: a–z, A–Z, 0–9, -, _, .
  • You can later run the saved Job from the Job Manager with one click.
save sync to jobs
You can view and run saved jobs by clicking the Job Manager toolbar in the Home menu.
verify job in job manager
