Virtual Remote Overview and Setup
Virtual Remotes add functional layers on top of existing cloud remotes. They do not store data themselves; instead, they make your current remotes more convenient, faster, safer, or more flexible.
What is a Virtual Remote?​
A Virtual Remote is a feature layer that:
  • Extends existing remotes without moving data.
  • Keeps storage in the original remote while adding convenience.
  • Helps with faster access, privacy, or unified views.
Types of Virtual Remotes​
RcloneView provides nine Virtual Remote types:
  1. Alias
    Shortcut to jump directly to a specific cloud folder.
    Example: bookmark a deep Google Drive path for instant access.
    👉 See: Alias Remote Guide
  2. Crypt
    Encrypt filenames, contents, and folders for privacy.
    👉 See: Crypt Remote Guide
  3. Memory
    Stores data in RAM for ultra-fast temporary usage; clears when closed.
  4. Cache
    Speeds up slow remotes with caching; faster repeated reads and streaming.
  5. Chunker
    Splits large files into chunks to bypass service size limits and improve stability.
  6. Combine
    Shows multiple folders under one remote as separate subfolders.
    👉 See: Combine Remote Guide
  7. Union
    Merges multiple folders into one unified view.
    👉 See: Union Remote Guide
  8. Hasher
    Adds hashing where the backend lacks it; useful for integrity checks.
  9. Compress
    Compresses files before upload to save space.
How to Add a Virtual Remote​
All Virtual Remotes are created from New Remote > Virtual.
add virtual remote
Step 1 — Open New Remote​
  • From the top menu: Remote > New Remote.
  • Choose the Virtual tab to see all Virtual Remote types.
Step 2 — Pick the Virtual Remote type​
Each type has its own required fields. Examples:
  • Alias: name + target folder.
  • Crypt: encryption password + target folder.
  • Union: multiple Remote:Path upstreams.
  • Combine: directory labels + remote paths list.
  • Chunker: source remote + chunk settings.
RcloneView guides you through the required inputs for each type.
Step 3 — Use the Virtual Remote​
After creation, the Virtual Remote appears just like any remote in:
  • Remote Manager
  • Explorer file browser
  • Sync / Compare / Job dialogs
Remember: Virtual Remotes are feature layers. Actual files stay in the underlying remote paths.
When to Use Virtual Remotes​
NeedRecommended Virtual Remote
Strengthen cloud securityCrypt
View multiple folders togetherUnion
Bookmark or tidy complex pathsAlias
Organize complex projectsCombine
Upload very large filesChunker
Speed up repeated readsCache
Verify data integrityHasher
Save storage with compressionCompress
Quick Reference​
Virtual RemoteRole
AliasFolder shortcut
CryptEncrypted storage
MemoryRAM-based temporary storage
CacheSpeed boost via caching
ChunkerChunk large files for upload
CombineGroup multiple folders as separate views
UnionMerge multiple folders into one view
HasherAdd hashing for integrity checks
CompressCompress files before upload
Virtual Remotes make cloud workflows more powerful and flexible. In RcloneView, you can enable these capabilities with just a few clicks—no complicated setup required.
