Union
How to Add Union Using RcloneView​
A Union Remote merges folders from multiple cloud remotes into a single unified folder. It is different from Combine:
  • Combine shows folders side by side.
  • Union merges multiple folders into one view.
Union is useful for:
  • Accessing data across remotes as if it were one folder.
  • Single-pane browsing and multi-cloud backup layouts.
  • Building a virtual filesystem without copying or moving data.
Create a Union Remote​
Step 1 — New Remote → Virtual → Union​
new remote add union
Step 2 — Enter Union details​
Fill in:
  • Remote name: e.g., MyUnion.
  • Upstreams (Remote:Path): Each Upstream is one actual folder location.
Add the first Upstream by selecting a remote and folder:
union select folder first
To add another Upstream, click Add Remote and pick the next folder:
union select folder second
Add as many Upstreams as needed, then review the settings:
union input window
Click Add Remote to create the Union remote.
Step 3 — Confirm in Remote Manager​
remote manager union
Check the Union in Explorer​
Open the Union remote in the Explorer. Contents from all Upstreams appear as one merged folder.
Upstreams 1 — Google Drive example
union check folder google drive
Matches mygoogledrive:Meet Recordings.
Upstreams 2 — Dropbox example
union check folder dropbox
Matches drop:assets.
Combine vs Union (Key Differences)​
FeatureCombine RemoteUnion Remote
Viewing styleShows multiple folders separatelyShows a single merged view
Writing rulesNot merged; separate foldersNew writes follow Union policies
File structureFolder1 / Folder2One combined virtual folder
Best forOrganizationMulti-cloud merging and unified usage
When to Use Union​
  • View data from several clouds at once in a single folder.
  • Projects split across remotes that need a unified view.
  • Run Sync/backup jobs against one virtual remote.
  • Provide a merged view without duplicating storage.
Summary​
FeatureDescription
Union RemoteMerges multiple Remote:Path entries into one view
UpstreamsActual remote folders that form the union
BenefitsMulti-cloud consolidation, single-pane access
PurposeUnified browsing, backups/Sync, project unification
Union Remote is a powerful virtual remote for managing multi-cloud environments through one merged folder view.
