Crypt
How to Add Crypt Using RcloneView​
A Crypt Remote adds an encryption layer on top of an existing cloud remote (Google Drive, OneDrive, etc.).
Files still live on the original remote, while the Crypt remote handles encryption and decryption.
Why it is useful:
  • Prevents providers from seeing file contents.
  • Can also encrypt filenames for full privacy.
  • Decryption happens automatically inside RcloneView.
  • Ideal for sensitive backups.
Why a Crypt Remote Can Look Empty​
Users often expect to see their plain files in a Crypt remote. Instead:
  • Crypt shows only encrypted files.
  • Plain files in the underlying remote are not shown in the Crypt view (this is normal).
Example:
  • mygoogledrive:Meet Recordings contains plain files.
  • MyCryptGoogle: wraps the same folder with Crypt.
  • In the Crypt remote it looks empty—this is expected.
When you upload via Crypt, files are stored encrypted, so:
  • They appear normally (decrypted) in the Crypt remote.
  • They appear with encrypted names in the original remote.
Create a Crypt Remote via New Remote​
Step 1 — Open New Remote → Virtual → Crypt​
new remote add crypt
Step 2 — Enter Crypt details​
Required fields:
  • Remote name: Name of the Crypt remote (e.g., MyCryptGoogle).
  • Remote (folder to encrypt): Click the folder picker to choose the existing remote and folder to protect.
select target remote and folder for crypt
After selection, review the settings and click Add Remote.
crypt input window
Step 3 — Confirm in Remote Manager​
remote manager crypt
Uploading and Viewing Files in a Crypt Remote​
When you upload through the Crypt remote:
  • Files are encrypted on upload.
  • The Crypt view shows decrypted names for convenience.
  • The underlying remote shows encrypted filenames.
Comparison example:
crypt upload file compare
View locationWhat you see
MyCryptGoogle:Plain-looking filenames (decrypted)
mygoogledrive:Meet RecordingsEncrypted filenames (expected)
Why Use a Crypt Remote​
  • Cloud providers cannot read file contents.
  • Filenames can be encrypted for full privacy.
  • Automatic decryption in RcloneView keeps usage simple.
  • Great for secure backups, sensitive documents, and shared drives.
  • Combine with scheduler for automated encrypted backups.
Summary​
FeatureDescription
Crypt RemoteEncryption layer over an existing remote
Plain files visibilityPlain files are hidden in Crypt view (normal)
Uploads via CryptStored encrypted; visible decrypted in Crypt view
PurposeSecure cloud backups and privacy protection
