Alias
How to Add Alias Using RcloneView​
An Alias Remote is a virtual remote that bookmarks a specific folder inside an existing cloud remote. Instead of drilling down a deep folder tree every time, click the Alias and the target folder opens immediately.
Use Alias when you:
  • Revisit deep project folders frequently.
  • Keep complex folder structures and need quick entry points.
  • Manage many remotes and want a cleaner layout.
  • Want to select specific folders faster in Sync / Compare / Jobs.
Summary: Alias = cloud folder bookmark.
Add an Alias Remote (via New Remote)​
Step 1 — Open New Remote and choose Virtual > Alias​
alias remote selection
Step 2 — Enter Alias info​
  1. Remote name: Enter the Alias name (e.g., MyAlias).
  2. Remote (target folder): Click the folder icon and pick the existing remote and folder you want.
    select target remote and folder
    After selecting, confirm the Alias details:
    alias input window
  3. Click Add Remote to create the Alias.
Step 3 — Check the Alias in Remote Manager​
remote manager alias
Open it in the file browser to confirm it points to the exact target folder:
alias file browser
Make an Alias Faster from the Explorer​
You can quickly create an Alias Remote to bookmark frequently used remote folders for faster and easier access.
  1. In the Explorer pane, click the ☆ Alias icon on the right side of the Path Bar.
  2. Enter a name for your new Alias.
  3. The remote will be instantly added and opened as an Alias Remote, ready for use.
add new alias remoteadd new alias remote nameadd new alias remote complete
Verify the Added Alias Remote in RcloneView​
The added Alias Remote can be verified the same way as any other cloud remote in RcloneView.
  1. From the top menu, click Remote Manager under the Remote tab.
  2. Confirm that your newly created Alias Remote appears in the Remote Manager window.
  3. Alternatively, open a new tab in the Explorer pane using the ☆ button and verify that the Alias Remote is available for browsing.
verify aws s3 step1added alias remote verifyadded alias remote explorer verify
Why Use Alias Remotes​
  • Save time: jump into deep folders with one click.
  • Keep Remote Manager tidy by surfacing key paths as separate entries.
  • Ideal for complex team/shared-drive structures.
  • Fully usable in Sync / Compare / Job workflows like any remote.
Summary​
FeatureDescription
Alias via New RemoteCreate a dedicated remote for a deep folder
Alias via ExplorerAdd the current folder as an Alias instantly
Remote Manager displayListed like any other remote
Use casesFast access, organization, automation
Alias is simple but powerful—flatten complex trees, jump straight to what matters, and speed up every cloud task.
