Combine
How to Add Combine Using RcloneView​
A Combine Remote merges folders from multiple cloud remotes into one virtual view. It does not copy or move data— it simply lets you browse several locations as a single folder.
Why it’s useful:
  • See data scattered across clouds in one place.
  • Treat project folders from different services as a single workspace.
  • Run backup/Sync jobs as if it were one remote.
  • No extra storage or duplicate files.
Combine Remote is effectively a multi-cloud viewer.
Create a Combine Remote​
Step 1 — New Remote → Virtual → Combine​
new remote add combine
Step 2 — Enter Combine details​
You need three fields for each entry:
  • Remote name: Name of the Combine remote (e.g., MyCombine).
  • Directory: Folder name as it will appear inside the Combine view (e.g., Folder1).
  • Remote Path: Actual cloud path to include. Click the folder icon to pick from registered remotes.
combine select folder first
After picking the first path:
combine select folder second
Use Add Remote to add Folder2, Folder3, and more.
When all entries are set:
combine input window
Click Add Remote to create the Combine remote.
Step 3 — Confirm in Remote Manager​
remote manager combine
Check Combined Folders in Explorer​
Open the Combine remote in the Explorer to see each added folder.
Folder1 — Google Drive example
combine check folder google drive
Shows the same contents as mygoogledrive:Meet Recordings.
Folder2 — Dropbox example
combine check folder dropbox
Shows the same contents as drop:assets.
When to Use Combine​
  • View data across multiple clouds at once.
  • Consolidate project folders split across remotes.
  • Manage backup or Sync jobs through a single virtual remote.
  • Keep original structures intact while unifying the view.
  • Avoid duplicate storage while gaining a combined workspace.
Summary​
FeatureDescription
Combine RemoteMerge multiple folders into one virtual view
No data duplicationFiles stay in their original locations
Add various remotesWorks with Drive, Dropbox, OneDrive, S3, etc.
Use casesUnified browsing, multi-cloud backup, projects
Combine Remote lets you manage multi-cloud data as if it lived in one place—without moving or duplicating files.
