Página sin clasificar
Esta página está sin clasificar. Los motores de búsqueda no la indexaran, y solo los usuarios con el enlace directo podrán acceder a esta.
Reference: RcloneView Blog/Tutorial Content Style Guide
· 21 min de lectura
Use this when generating new RcloneView articles. Keep CTAs, imports, imagery, and links consistent.
Writing Tips​
  • Always follow the CTA & Component Template (required) rules (imports, RvCta block, <CloudSupportGrid />).
  • From the GUI Image Reference list, place the image link that best matches the section you’re writing.
  • Add related guide links from the How-to list that match the topic you’re covering.
  • For existing documents, replace images with the closest matches from the image list.
  • For existing documents, add or swap guide links using the closest matches from the How-to list.
CTA & Component Template (required)​
  • Place imports immediately after front-matter, with exactly one blank line after the front-matter block, and do not duplicate them:
    import CloudSupportGrid from '../src/components/CloudSupportGrid';
    import cloudIcons from '../src/contexts/cloudIcons';
    import RvCta from '../src/components/RvCta';
  • After <!-- truncate -->, insert the RvCta block above.
  • End the document with <CloudSupportGrid /> on its own line.
RcloneView GUI Image References​
Use these to show the actual UI (sourced from Jay-authored posts). Copy-paste the HTML image tags:
  • New Remote screen:
  • Two-pane Explorer (remotes open):
  • Drag & Drop in Explorer:
    drag and drop
  • Compare folders and copy:
    Compare shared folder and My Drive contents
  • Job Management, Job Execution
  • Job execution monitoring:
    transfer monitoring
  • Job scheduling & automation setup:
    create job schedule
  • Job History
job history
  • Create Mount
    • Directly mount from opened remote/folder
      mount from remote explorer
    • Mount with Mount Manager
  • RcloneView Connecting with Embedded Rclone
embedded rclone model
  • RcloneView Connecting with External Rclone
external rclone model
  • Synology NAS Connection.
synology nas autodection and connection
Use these to show the actual UI. Copy-paste the HTML image tags:
Icons​
  • disabled delete mount configuration disabled-delete-mount-configuration.png
  • find folder with next smaller change find-folder-with-next-smaller-change.png
Cloud Icons​
Images (English / blog)​
  • open backblaze b2 and dropbox remote open-backblaze-b2-and-dropbox-remote.png
  • synology nas autodection and connection synology-nas-autodection-and-connection.png
Images (English / howto ? FAQ)​
  • change setting for accessing to files and folders change-setting-for-accessing-to-files-and-folders.png
  • creat alias remote for external hdd creat-alias-remote-for-external-hdd.png
  • mac allow access to folder and files1 mac-allow-access-to-folder-and-files1.png
  • mac allow access to folder and files2 mac-allow-access-to-folder-and-files2.png
Images (English / howto ? core)​
Images (English / howto ? rcloneview-advanced)​
Images (English / howto ? rcloneview-basic)​
  • connection manager with embedded rclone only connection-manager-with-embedded-rclone-only.png
  • embedded rclone advanced options settings embedded-rclone-advanced-options-settings.png
  • embedded rclone logging configuration settings embedded-rclone-logging-configuration-settings.png
Images (English / howto ? cloud-storage-setting)​
Images (English / howto ? remote-storage-connection-settings ? root)​
  • google drive shared with me options google-drive-shared-with-me-options.png
  • on home quick access wizard for storj on-home-quick-access-wizard-for-storj.png
  • on home quick access wizard for wasabi on-home-quick-access-wizard-for-wasabi.png
Images (English / howto ? remote-storage-connection-settings ? alias)​
  • virtual add select remote and folder virtual-add-select-remote-and-folder.png
Images (English / howto ? remote-storage-connection-settings ? azure-file-storage)​
Images (English / howto ? remote-storage-connection-settings ? combine)​
Images (English / howto ? remote-storage-connection-settings ? connect-using-cli)​
Images (English / howto ? remote-storage-connection-settings ? crypt)​
Images (English / howto ? remote-storage-connection-settings ? union)​
Images (English / tutorials)​
  • add new wasabi remote configuration add-new-wasabi-remote-configuration.png
  • browsing aws s3 and google drive via ec2 rclone browsing-aws-s3-and-google-drive-via-ec2-rclone.png
  • chunk size and upload concurrency settings chunk-size-and-upload-concurrency-settings.png
  • compare synology nas and google drive compare-synology-nas-and-google-drive.png
  • high transfer speed with chunk size and upload concurrency high-transfer-speed-with-chunk-size-and-upload-concurrency.png
  • open aws s3 and cloudflare r2 remotes open-aws-s3-and-cloudflare-r2-remotes.png
  • sync aws s3 and google drive via ec2 sync-aws-s3-and-google-drive-via-ec2.png
  • synology nas to google drag and drop synology-nas-to-google-drag-and-drop.png
  • synology nas webdav and google drive synology-nas-webdav-and-google-drive.png
  • transfer files between aws s3 and cloudflare r2 with external rclone transfer-files-between-aws-s3-and-cloudflare-r2-with-external-rclone.png
  • transfer files between aws s3 and cloudflare r2 transfer-files-between-aws-s3-and-cloudflare-r2.png
  • transfer files between box and google drive transfer-files-between-box-and-google-drive.png
  • transfer files between mega and google drive transfer-files-between-mega-and-google-drive.png
  • transfer files between onedrive and dropbox transfer-files-between-onedrive-and-dropbox.png
  • transfer speed with default options transfer-speed-with-default-options.png
  • wasabi real time monitoring transferring wasabi-real-time-monitoring-transferring.png
  • wasabi remote in rcloneview explorer wasabi-remote-in-rcloneview-explorer.png
  • telegram newbot rcloneview test bot telegram-newbot_rcloneview_test_bot.jpg
Images (howto root)​
Images (root /img)​
  • favicon favicon.ico
  • logo allWhite logo_allWhite.svg
  • logo white logo-white.svg
  • logo logo.svg
  • undraw docusaurus mountain undraw_docusaurus_mountain.svg
  • undraw docusaurus react undraw_docusaurus_react.svg
  • undraw docusaurus tree undraw_docusaurus_tree.svg
Videos​
  • /support/videos/en/howto/rcloneview-basic/rclonview-explorer-drag-and-drop.mp4
  • /support/videos/en/howto/rcloneview-basic/windows-explorer-drag-and-drop.mp4
