Zero-CLI Encryption with RcloneView Crypt Remote: Protect Any Cloud Folder
Cloud storage is convenient, but convenience is not the same as privacy. RcloneView's Crypt Remote lets you encrypt files before upload, without CLI commands or complex flags.
More teams are choosing encrypt-before-upload as the default strategy. It protects against unintended exposure from account compromise, internal audits, regional compliance scans, or false-positive security reviews. The challenge has always been complexity. RcloneView removes that barrier with a simple Crypt Remote workflow.
What is a Crypt Remote in RcloneView?​
A Crypt Remote is an encrypted view layered on top of an existing remote.
  • Base Remote: where the encrypted data actually lives (Drive, S3, WebDAV, etc.)
  • Crypt Remote: the view you work in (decrypted for you)
RcloneView automatically encrypts file contents, and optionally file names, before upload.
[Crypt Remote]  -> decrypted view for you
v
[Base Remote] -> encrypted data stored in the cloud
To the provider, the files are unreadable and filenames look like random strings.
When should you use Crypt?​
Sensitive business documents​
Contracts, finance data, client files, or internal plans should not be readable by a provider.
Personal archives and long-term backups​
Family photos, identity documents, and private records deserve encryption by default.
Shared or third-party storage​
Company-owned accounts, external vendor storage, or NAS + cloud hybrids are safer with an encryption layer.
Step-by-step: create a Crypt Remote (no CLI)​
1) Open New Remote​
Go to Remote Manager → New Remote, then choose Virtual → Crypt.
Add Crypt remote
2) Select the base remote​
Pick the remote and folder you want to encrypt. You can target a specific folder to keep encrypted data separated.
Select target folder for crypt
3) Set encryption passwords​
  • Data Password: required
  • Filename Password: optional, use this to hide file names too
These passwords are not recoverable. Store them securely.
4) Confirm and finish​
The new Crypt Remote appears in Remote Manager while the base remote remains unchanged.
Crypt remote in Remote Manager
Guide: /support/howto/remote-storage-connection-settings/crypt-remote
Understanding the two views (very important)​
Base Remote view
Encrypted filenames and unreadable binary data. This is expected.
Crypt Remote view
Decrypted files and normal names. This is where you should work.
If the Crypt view looks empty, you likely uploaded files directly to the base remote. Always upload through the Crypt Remote.
Crypt vs base view comparison
Using Crypt in real RcloneView workflows​
Crypt remotes behave like normal remotes:
Drag and drop into CryptCompare results filters
Sync configure storageSave sync to Jobs
Best practices and warnings​
  • Passwords are unrecoverable: use a password manager.
  • Back up rclone.conf: it contains crypt keys.
  • Do not mix plain and encrypted files in the same folder.
  • Test first with a small folder and a dry run.
Sync dry run
FAQ​
Does encryption slow transfers?
There is some CPU overhead, but network speed is usually the bottleneck.
Can I decrypt outside RcloneView?
Yes. Any rclone client with the same crypt config and passwords can decrypt.
What if I lose the password?
Data is not recoverable. This is the tradeoff of zero-knowledge security.
Conclusion​
Encrypt first, then automate. RcloneView’s Crypt Remote gives you privacy-first backups without the CLI. Set it once, use Compare/Sync/Jobs as usual, and keep control of your data.
