Fix OneDrive Sync Errors: Delta Token Expired, Path Too Long, and Auth Failures
· 5 min read
OneDrive is a capable cloud storage platform, but its sync behavior has some quirks that can trip up rclone users. This guide covers the most common OneDrive errors you'll encounter in RcloneView and how to resolve each one.
OneDrive works well for the vast majority of rclone operations, but certain error conditions are unique to Microsoft's platform. Delta token expiry, Windows path length limits, authentication token refresh failures, and per-file or per-day upload quotas all appear in real-world usage. Here's a systematic guide to diagnosing and fixing each one.
Error 1: Delta Token Expired​
Symptom: You see an error like:
Failed to sync: invalidDeltaToken: The token is expired.
Cause: Rclone uses a delta token to track incremental changes in OneDrive. This token has an expiry of approximately 30 days. If you haven't run a sync in over a month — or if Microsoft invalidated the token — rclone cannot continue the incremental scan.
Fix: Force a full rescan by removing the cached delta token:
  1. In RcloneView, open the Terminal panel.
  2. Run: rclone backend remove-expiry onedrive: (replace onedrive with your remote name).
  3. Alternatively, delete the vfs/delta cache entry for the remote from RcloneView's config.
  4. Re-run the sync job — rclone will perform a full scan this time.
This takes longer on the first run after the fix but resolves the error completely.
Error 2: Path Too Long (> 400 Characters)​
Symptom:
ERROR: path too long: cannot handle path > 400 characters
or files failing to sync from deeply nested folders.
Cause: OneDrive enforces a maximum path length of 400 characters (for OneDrive Personal) or 400 characters for OneDrive for Business. Windows also has legacy 260-character MAX_PATH limits that affect the OneDrive desktop sync client, though rclone itself doesn't have this Windows limitation.
Fix:
  • Shorten your folder structure — keep directory nesting shallow. Rename long folder names.
  • Use a shorter base path in OneDrive — if you're syncing to OneDrive/Clients/Projects/2026/Active/Reports/, consider flattening to OneDrive/Projects-2026/Reports/.
  • Use RcloneView's filter rules to skip folders with known path length problems while you restructure them.
Use folder comparison to identify path issues
Error 3: Authentication Errors (401 Unauthorized)​
Symptom:
401 Unauthorized
Failed to refresh token
AADSTS700082: The refresh token has expired
Cause: Microsoft's OAuth refresh tokens expire if unused for 90 days or after a password change / security policy reset. When the stored token in rclone's config becomes invalid, all operations fail.
Fix: Re-authorize the OneDrive remote in RcloneView:
  1. Open Remotes in RcloneView.
  2. Select your OneDrive remote and choose Edit.
  3. Click Re-authorize — a browser window opens for Microsoft login.
  4. Log in and grant access again.
  5. Save the updated token.
Future operations will use the fresh token. Set a reminder to re-authorize if you run infrequent sync jobs (monthly or less).
Error 4: 429 Too Many Requests / Rate Limiting​
Symptom:
429 Too Many Requests: request throttled
Cause: OneDrive's API enforces per-user rate limits. Syncing thousands of small files rapidly triggers throttling.
Fix:
  • Reduce concurrent transfers — in RcloneView's job settings, lower the transfer count to 2–4.
  • Add a rate limit — use the --tpslimit 10 flag in RcloneView's custom flags field to limit transactions per second.
  • Schedule during off-peak hours — Microsoft's throttling is more aggressive during business hours.
  • Use chunk uploads for large files — RcloneView handles this automatically for files over 100 MB.
Schedule OneDrive jobs during off-peak hours
Error 5: Quota Exceeded​
Symptom:
403 Forbidden: insufficient storage
or uploads silently failing when OneDrive is near capacity.
Cause: The target OneDrive account has insufficient free space.
Fix:
  • Check your OneDrive quota in the Microsoft 365 admin center or at onedrive.live.com.
  • Free up space by deleting or moving old files from OneDrive.
  • Upgrade your plan if the account is legitimately full.
  • Split the migration — move files to a different OneDrive account or switch to a different destination for the overflow.
Error 6: Invalid Characters in File Names​
Symptom: Files with certain characters fail to transfer to OneDrive.
Cause: OneDrive prohibits certain characters in file names: \, /, :, *, ?, ", <, >, |. Files coming from Linux systems often have colons or other characters in their names.
Fix: RcloneView (via rclone) has a built-in --onedrive-enc encoding option that automatically replaces prohibited characters with Unicode lookalikes. Enable this in the advanced settings for your OneDrive remote.
Monitoring Errors in RcloneView​
The Job History panel in RcloneView shows transfer logs with full error messages for each file:
View OneDrive error logs in RcloneView
Use this to quickly identify which files failed and why, without digging through rclone's raw log output.
  2. Check Job History for error messages when a sync fails.
  3. Apply the fix for the specific error type using the guidance above.
  4. Re-run the job — rclone will skip successfully transferred files and retry only the failures.
Most OneDrive errors have straightforward fixes. The key is identifying the exact error message and applying the targeted solution rather than debugging blindly.
