Fix SFTP Public Key Authentication Errors — Resolve SSH Issues with RcloneView
SFTP public key authentication failures are almost always caused by key path, file permission, or passphrase mismatches — this guide walks through each one systematically.
SFTP is one of the most common ways to connect remote Linux servers in RcloneView, and public key authentication is the preferred security method over passwords. When key auth fails, the errors can be cryptic: ssh: handshake failed, permission denied (publickey), or no supported methods remain. This guide covers the most frequent causes and how to diagnose and fix each one.
SFTP Remote Configuration in RcloneView​
When you create an SFTP remote in RcloneView, the relevant fields for key-based auth are:
  • Host: the server hostname or IP
  • User: the SSH username
  • Key file: the path to your private key file (e.g., ~/.ssh/id_rsa or C:\Users\you\.ssh\id_ed25519)
  • Key file passphrase: the passphrase that decrypts the key (if set)
Password auth and key auth are mutually exclusive per remote. If you specify a key file, leave the password field empty.
SFTP remote configuration with key auth in RcloneView
Common Error 1: Wrong Key File Path​
The most frequent cause of key auth failure is a wrong or unreachable key file path. Check:
  • The path exists and points to the private key (not the .pub public key)
  • On Windows, use the full absolute path (e.g., C:\Users\username\.ssh\id_rsa)
  • On Linux/macOS, ~/.ssh/id_rsa expands correctly — if in doubt, use the full path
In RcloneView, open the SFTP remote settings and verify the key file path. If the file doesn't exist at that location, the authentication will fail silently or with an unhelpful error.
Common Error 2: Key File Permissions Too Open​
On Linux and macOS, SSH refuses to use private key files that are world-readable. If the key file permissions are too permissive, you'll see Permissions 0644 for '~/.ssh/id_rsa' are too open. Fix it:
chmod 600 ~/.ssh/id_rsa
chmod 700 ~/.ssh
On Windows, key file permissions are managed through file security settings. Ensure the key file is accessible only to your user account and not shared with Everyone.
Running an SFTP connection test in RcloneView
Common Error 3: Passphrase Mismatch​
If your private key is passphrase-protected, the passphrase field in the RcloneView SFTP remote settings must match exactly. A blank passphrase field when the key has one set will cause auth to fail. Conversely, entering a passphrase for a key that doesn't have one will also fail.
To test whether your key passphrase is correct, open a terminal and run ssh -i /path/to/key user@host — if it prompts for the passphrase and accepts it, the credentials are correct. Then update the RcloneView remote accordingly.
Common Error 4: Key Format Not Supported​
Older OpenSSH private keys (PEM format) are broadly supported, but some newer ED25519 keys in the OpenSSH native format may cause issues depending on the Go SSH library version embedded in rclone. If you encounter ssh: no supported methods remain:
  • Convert the key to PEM format: ssh-keygen -p -m PEM -f ~/.ssh/id_ed25519
  • Or generate an RSA key: ssh-keygen -t rsa -b 4096
Reading Logs for Diagnosis​
Open the Log tab in RcloneView after a failed SFTP connection attempt. The log shows the full SSH handshake error. For additional verbosity, use the Terminal tab in RcloneView to run an rclone command with -vv flags directly, which prints the complete SSH negotiation.
Reviewing SFTP connection errors in RcloneView logs
  2. Open your SFTP remote settings and verify the key file path points to the correct private key.
  3. On Linux/macOS, check key file permissions with ls -la ~/.ssh/ and fix with chmod 600.
  4. Confirm the passphrase field matches your key's passphrase, then test the connection from Remote Manager.
Systematic checking of path, permissions, and passphrase resolves the vast majority of SFTP public key authentication failures.
