Fix 'Permission Denied' and Access Errors in Cloud Sync — Troubleshooting Guide for RcloneView
· 3 min read
Nothing is more frustrating than a sync job that fails at file 4,237 with "Permission Denied." These errors have specific causes, and most are fixable in minutes.
Permission and access errors are among the most common issues when syncing between cloud providers. Whether it's a 403 Forbidden from Google Drive, an Access Denied from S3, or a Permission Denied from OneDrive, the root cause usually falls into a handful of categories. This guide covers each one with practical fixes.
Common Permission Errors by Provider​
Google Drive: 403 Forbidden​
Causes and fixes:
  • API quota exceeded — Google limits API calls per 100 seconds. Reduce concurrent transfers or add a --tpslimit flag via RcloneView's terminal.
  • Shared Drive permissions — you need "Content Manager" or higher access on Shared Drives. Viewer access is read-only.
  • OAuth token expired — re-authorize the remote in RcloneView's remote manager.
OneDrive / SharePoint: Access Denied​
Causes and fixes:
  • File locked by another user — SharePoint locks files that are open in Office apps.
  • Path too long — OneDrive has a 400-character path limit. Shorten nested folder names.
  • Admin restrictions — Microsoft 365 admins can restrict third-party app access. Check with your IT team.
S3: 403 Access Denied​
Causes and fixes:
  • IAM policy too restrictive — your access key needs s3:GetObject, s3:PutObject, s3:ListBucket at minimum.
  • Bucket policy conflict — bucket-level policies can override IAM permissions.
  • Wrong region — accessing a bucket from the wrong region endpoint can cause errors.
General: Permission Denied on specific files​
Causes and fixes:
  • Read-only files — some providers mark system files or shared files as read-only.
  • Special characters in filenames — characters like ?, *, | cause issues on certain providers.
  • File size limits — some providers reject files above certain sizes.
How to Diagnose in RcloneView​
Check job history​
Check error details in job history
Job history shows which specific files failed and why. Look for patterns — if all failures are in the same folder, it's likely a permissions issue on that folder.
Use the built-in terminal​
For detailed diagnostics, use RcloneView's terminal to run rclone commands with -vv verbose output. This shows the exact API response from the provider.
Prevention Strategies​
  • Test with a small folder first before running large sync jobs
  • Use dry-run mode to preview what would transfer without actually moving files
  • Monitor job history regularly for early error detection
  • Keep OAuth tokens fresh by re-authorizing periodically
  2. Check your remote permissions in the remote manager.
  3. Run a test sync on a small folder first.
  4. Review job history for detailed error information.
Most permission errors have simple fixes — the key is knowing where to look.
