Fix SFTP Connection Refused and Timeout Errors in RcloneView
· 6 min read
SFTP errors in RcloneView almost always trace back to network configuration, authentication setup, or server-side settings. This guide walks through every common cause and fix.
SFTP (SSH File Transfer Protocol) is one of the most widely used remotes in rclone, connecting RcloneView to any server with SSH access — NAS devices, Linux servers, shared hosting, and self-hosted infrastructure. Unlike cloud provider APIs, SFTP depends on network reachability, firewall rules, and SSH configuration, which means there are more points of failure. Here is how to diagnose and resolve the most common SFTP issues.
Common SFTP Error Messages​
Error MessageLikely Cause
connection refusedSSH server not running, wrong port, or firewall block
connection timed outFirewall dropping packets, server unreachable, or network issue
ssh: handshake failedSSH key mismatch, incompatible algorithms, or server-side config
permission denied (publickey)Wrong key file, key not authorized on server, or passphrase issue
permission denied (password)Incorrect password or password auth disabled on server
no supported methods remainServer requires auth method that rclone is not configured to use
ssh: unable to authenticateCredentials not provided or rejected
too many authentication failuresSSH agent offering too many keys before the right one
View SFTP error details in RcloneView job history
Fix 1: Connection Refused​
A "connection refused" error means the TCP connection was actively rejected. The server's network stack is reachable, but nothing is listening on the target port.
Check That SSH Is Running​
On the remote server, run sudo systemctl status sshd. If SSH is not running, start it with sudo systemctl start sshd && sudo systemctl enable sshd.
Verify the Port​
The default SSH port is 22, but many servers use a custom port. Check with grep -i "^Port" /etc/ssh/sshd_config. In RcloneView, ensure the SFTP remote's port setting matches. A mismatch between port 22 and a custom port like 2222 is one of the most common causes.
Configure SFTP remote port in RcloneView
Check for Local Firewall Blocks​
On the server, verify the firewall allows inbound connections on the SSH port. Use sudo ufw status (Ubuntu/Debian), sudo firewall-cmd --list-ports (RHEL/Fedora), or sudo iptables -L -n | grep 22. If the port is blocked, add a rule to allow it.
Fix 2: Connection Timeout​
A timeout means packets are being sent but no response is received. This is typically a network-level issue rather than a server-side configuration problem.
Network Reachability​
Test basic connectivity from your machine:
ping server-hostname
telnet server-hostname 22
If ping succeeds but telnet to port 22 fails, a firewall between you and the server is blocking the SSH port.
Router and NAT Firewalls​
If the SFTP server is behind a NAT router, ensure port forwarding is configured to route external traffic on the SSH port to the internal server IP. Without port forwarding, connections from outside the local network will time out.
ISP or Corporate Firewall Blocks​
Some ISPs and corporate networks block outbound connections on port 22. Test with an alternative port or use a VPN to bypass the restriction.
Timeout Tuning in Rclone​
Rclone's default connection timeout may be too short for high-latency connections. You can increase it by adding the --contimeout flag. For SFTP-specific server response delays, consider setting --timeout to a higher value (e.g., 5m for slow servers).
Fix 3: SSH Key Authentication Failures​
Key-based authentication is the most secure and recommended method for SFTP connections, but misconfiguration is common.
Verify Key File Path​
In RcloneView, the SFTP remote configuration includes a field for the SSH key file path. Ensure:
  • The path points to the private key (e.g., ~/.ssh/id_rsa or ~/.ssh/id_ed25519), not the public key.
  • The file exists and is readable by your user account.
  • The key file has correct permissions (600 on Linux/macOS).
Authorize the Key on the Server​
The public key must be listed in ~/.ssh/authorized_keys on the server. Append it with cat ~/.ssh/id_ed25519.pub >> ~/.ssh/authorized_keys, then ensure permissions are 600 for the file and 700 for the .ssh directory.
Passphrase-Protected Keys​
If your private key has a passphrase, rclone needs it to decrypt the key. In RcloneView's SFTP remote config, enter the passphrase in the appropriate field. If you leave it blank, authentication will fail silently.
SSH Agent Conflicts​
If an SSH agent is running with many loaded keys, the server may reject the connection after too many failed key attempts (default limit is usually 6). Either specify the exact key file in the rclone config to bypass the agent, or reduce the number of keys loaded in your agent.
Fix 4: Password Authentication Issues​
Password Auth Disabled on Server​
Many servers disable password authentication for security. Check with grep -i "PasswordAuthentication" /etc/ssh/sshd_config. If set to no, you must use key-based authentication instead.
Incorrect Password​
Ensure you are entering the correct password in RcloneView's SFTP remote configuration. Rclone stores the password in an obscured format in rclone.conf — if you edit the config manually, use rclone obscure to encode the password properly.
Fix 5: Concurrent Connection Limits​
SFTP servers often limit the number of simultaneous sessions. Rclone defaults to 4 concurrent transfers, but some servers allow only 1 or 2 connections.
If you see intermittent connection failures during large transfers, reduce concurrency:
  • Set --transfers 1 or --transfers 2 to limit parallel connections.
  • Set --checkers 1 to reduce the number of simultaneous check operations.
Some shared hosting providers are especially restrictive. Start with low concurrency and increase gradually.
Monitor SFTP transfer progress in RcloneView
Fix 6: SSH Algorithm Incompatibility​
Older servers may not support modern SSH algorithms, or hardened servers may reject older algorithms. If you see "handshake failed" errors, update the SSH server software if possible, or check /etc/ssh/sshd_config for KexAlgorithms, Ciphers, and MACs restrictions.
RcloneView explorer with SFTP remote connected
  2. Add an SFTP remote with correct host, port, and authentication settings.
  3. Test the connection by browsing the remote in the explorer.
  4. Run through the checklist above if you encounter errors.
SFTP issues are almost always configuration problems, not software bugs. Methodically checking each layer — network, firewall, authentication, and server settings — resolves the vast majority of cases.
