Why Are My Cloud Uploads So Slow? Speed Optimization Tips with RcloneView
· 5 min read
You start a cloud upload expecting 30 minutes. Two hours later, it's at 40%. Before you blame your internet, the problem might be your tool — not your connection.
Slow cloud transfers are frustrating, but they're rarely caused by a single issue. It's usually a combination of default settings that aren't optimized for your situation, provider-specific throttling, and inefficient transfer methods. RcloneView gives you the controls to fix all of these.
Why Cloud Transfers Are Slow​
1) Single-threaded transfers​
Most cloud sync tools upload one file at a time. If you have 10,000 small files, each file requires a separate HTTP connection — setup, transfer, verification. The overhead per file can exceed the actual transfer time.
Fix: Increase parallel transfers. Rclone defaults to 4, but many connections can handle 8–16 or more.
2) Small chunk sizes​
Large files are uploaded in chunks. If the chunk size is too small, each chunk requires its own HTTP request, adding overhead. If it's too large, a failed chunk means re-uploading more data.
Fix: For stable connections, increase chunk size. For Google Drive, try 64M or 128M. For S3, try 16M–64M.
3) Provider rate limits​
Cloud providers throttle uploads to prevent abuse:
  • Google Drive: ~750 GB/day upload limit.
  • OneDrive: Throttling after sustained high throughput.
  • Dropbox: Progressive throttling under heavy load.
  • S3: 3,500 PUT requests/second per prefix.
Fix: Respect rate limits by adjusting transfer speeds. Use bandwidth limiting to stay under thresholds.
4) No server-side copy​
When transferring between two clouds (e.g., S3 to S3), some tools download to your machine then re-upload. Rclone supports server-side copy for compatible providers — data moves directly between clouds without touching your machine.
Fix: RcloneView uses server-side copy automatically when available.
5) Checking every file​
Before transferring, rclone checks if each file already exists at the destination. With large file counts, this checking phase can take longer than the actual transfer.
Fix: Use --no-check-dest for initial bulk transfers. Use normal checking for incremental syncs.
Speed Optimization Settings​
Parallel transfers​
Increase the number of simultaneous file transfers:
ScenarioRecommended Setting
Default4 transfers
Fast internet (100+ Mbps)8–16 transfers
Many small files16–32 transfers
Large files only4–8 transfers
More parallel transfers help with many small files. For a few large files, chunk size matters more.
Chunk size by provider​
ProviderDefault ChunkRecommended
Google Drive8 MB64–128 MB
OneDrive10 MB64 MB
S35 MB16–64 MB
Dropbox48 MB48–150 MB
Larger chunks mean fewer HTTP requests and less overhead.
Buffer size​
Increase the in-memory buffer for faster reading:
  • Default: 16 MB
  • Recommended: 64–256 MB (if you have the RAM)
This helps when reading from slow sources (NAS, spinning disks).
Monitor and Measure​
Track transfer speed in real time to see the effect of your changes:
Monitor transfer speed in real time
What to watch​
  • Transfer speed — Should match a reasonable percentage of your internet upload speed.
  • Active transfers — Should match your parallel transfer setting.
  • Errors — Rate limit errors (429, 403) mean you need to slow down.
  • Checks vs transfers — If checking takes too long, consider skipping for initial uploads.
Provider-Specific Tips​
Google Drive​
  • Set chunk size to 64M or higher.
  • Keep parallel transfers at 4–8 (Google throttles aggressively above this).
  • If you hit the 750 GB daily limit, schedule transfers across multiple days.
OneDrive / SharePoint​
  • Use 4–8 parallel transfers.
  • Chunk size 64 MB works well.
  • OneDrive throttles based on total volume — spread large transfers over time.
AWS S3​
  • S3 handles high parallelism well — try 16–32 transfers.
  • Use multipart upload for files over 100 MB.
  • Choose an S3 region close to your location for lower latency.
Backblaze B2​
  • Supports high parallelism — 16+ transfers work well.
  • Chunk size doesn't apply (B2 uses its own large file API).
  • No daily transfer limits.
Batch Jobs for Optimized Workflows​
With v1.3 Batch Jobs, chain an optimized transfer sequence:
  1. Bulk transfer with aggressive settings.
  2. Verification comparison.
  3. Notification when complete.
Batch optimized transfer workflow
Quick Checklist​
  • Increase parallel transfers — especially for many small files.
  • Increase chunk size — especially for large files.
  • Check your internet speed — speedtest-cli to baseline your connection.
  • Monitor rate limits — watch for 429/403 errors in transfer logs.
  • Use server-side copy — when transferring between compatible clouds.
  • Schedule large transfers — off-hours to avoid impacting your network.
  2. Tune your transfer settings in the job configuration.
  3. Monitor speed in real time.
  4. Adjust and iterate — small changes can dramatically improve throughput.
The default settings work for most situations. But when you're moving terabytes, optimization pays off quickly.
